Hi, I am actually reparing a Arturia keylab 49 midi controller and I am looking for the base where you fix the keys (see the link for pictures). One of the plastic parts that retain the key in position is broken and I do not have it anymore to glue it back on the frame, so I’m looking to replace it. It may come with or without the aftertouch strip. Also, if you have a DIY trick to replace that part so I dont have to replace the whole thing, it would be very cool! Thanks!
Did you ever get any nibbles on that? I’ve got at least a half dozen high keys on my Keylab. From everything I’ve read, Arturia basically had a bad run of keybeds for some of the Keylab49’s production run - bad batch of plastic or somesuch. The bosses that limit the key travel are really brittle, and they start breaking off if you so much as look at the thing. I’m at the point now where I think I’m going to design a brass or aluminum piece that will fix, I dunno, an octave at t time, or maybe the entire keybed, and get a friend to CNC-machine it for me. Either that, or 3dprint individual bosses out of plastic and epoxy 'em to the front edge of the bed.
