I got in an Ensoniq ESQ-1 that the 5th voice does not play.
I ran the test and all filters come up good, I even swopped the ICs with and other ESQ-1 I have and still voice 5 does not work.
Does any one have any ides or a schematic ?
Thanks
http://www.buchty.net/ensoniq/
http://zine.r-massive.com/ensoniq-technical-documents-and-schematics/
I would check the capacitors around the IC first. Make sure one is not open or shorted, etc.
Thanks,
Johnny
Thanks
I’ll check the caps.
You were right, it was a shorted capacitor to ground on pin 12 of CEM3379.
Thanks for you help.
Jon
Awesome. Caps are probably the issue 90% of the time. I usually check them all if I have to take the board out. A simple ohm meter that has a continuity beep is a quick way. If it beeps continuously in both directions, it’s usually a sign of going bad. It will beep once if there is a charge of course, but it should stop when checking again when swapping +/-. You do not have to remove them from the board to test in this way either for the most part. If you suspect a bad one after testing, then remove it and test again, etc.
