Help identifying ribbon cable for FATAR 26612780 contact board
Hello! I’m trying to find the correct ribbon cable for a FATAR 26612780 key-contact board that I found here on Syntaur. The part number on the website is 5740 Key contact board, 39-note (Low)
The replacement board uses the newer black 20-pin connector, while my original board used the older red connector. I need a cable that connects this newer black 20-pin connector to the 20-pin connector on my piano’s main board.
Does anyone know the exact connector type or cable I would need for this board? i just need this one last piece and my piano will start working again! I cannot find it anywhere online.
I’ll attach a picture of the main connector that’s giving me problems.
Thank y’all so much for any help!
What is the make and model of the keyboard that you are trying to install this board into?
That 26612780 PCB is standard FATAR TP/9S or TP/7 series keybed contact board used across Ensoniq, Kurzweil, and Novation controllers.
The interconnect ribbon is a 1.25mm pitch flexible flat cable (FFC) or 1.0mm depending on revision, usually terminating in a friction-fit ZIF or crimp header. If you have cracked conductors inside the fold, you don’t necessarily have to find an OEM FATAR harness: standard AWM 20624 80C 60V ribbon cable with matching pin count and pitch will seat directly into the header. Measure the pin pitch with a digital caliper pin-to-pin before ordering.
Also make sure the carbon contact pads under the rubber plungers haven’t oxidized or separated from the trace traces while the cable was dislodged.
