Hey Everybody,
I recently had the Analog Renaissance GS Voice Chips installed and the Module board calibrated.
I am wanting to know if I calibrate the power supply without the module board connected, when i reconnect the module board, will it mess up the calibration? I know when everything is connected if you change the voltage it can and then you would have to start over the whole process.
Am I able to do that?
