Greetings from Japan!
I am rebuilding a Korg DW-6000 I picked up recently.
(1) I’ve rebuilt the PSU so now it actually works.
(2) I am going to change the battery holder just waiting for the part.
(3) I noticed that on headphones there is a mains hum 50hz over here that doesn’t change with volume settings. If I use the phono outputs there is no noise. Has anyone had that one before?
(4) It has been dropped on its end, right side during its life. The end piece has a couple of cracks in it and the top C key was floating. I gently removed the key, but there was a bit broken off at the back of the key and also one of the plastic posts built into the support has broken away, so I will have to make some kind of replacement post.
It looks like the top C key is hard to find. Does anyone know of a modern replacement for the top C on a DW6k?
Best regards
Tee.
