I just got an OEX-6 for my EPS-16 Plus keyboard (it’s a Turbo). I hooked it up with the power off, and when I turned it on I heard a noise through my speakers and the EPS wouldn’t boot. Only some of the bank LEDs light up (5, 6, and 8) and the display barely gets any light. I opened it up and found F1 and F2 (the 1.5 A fuses) on the power supply board blown. The other fuses are fine. New fuses are on the way, and I’m really hoping that’s all it is.
The cable I used is the one sold on eBay as an OEX-6 cable (“not a standard cable, wired specifically for this application”). I metered it: the pins are mirrored left to right, and only the centre pins go straight across.
From Ensoniq’s main board schematic, the EPS-16 Plus OEX jack (J8) is pin 6 ground, pin 7 +15 V, pin 8 −15.6 V, and pins 1-5 are data and clock.
I found the threads here where @ramjet1962 says a standard cable will damage the EPS and that you need a special one. So I’m guessing the mirrored cable is right, and my OEX-6 might be what failed. But I’d like to know for sure before I plug anything in again.
Does anyone have an original Ensoniq OEX-6 cable they could meter? Straight or mirrored?
@ramjet1962, could you share the pin connections you used? And what did you end up having to repair on your ASR-10?
Is there a safe way to test an OEX-6 before connecting it to the EPS?
I’ve got photos of the fuses and the cable test if they help. Thanks!
The eBay seller sent me the pinout: 1-2, 2-1, 3-5, 4-4, 5-3, 6-8, 7-7, 8-6. It’s a standard mini-DIN 8 crossover, the same as what I metered.
So I tested it end to end with both units unpowered.
Tip for anyone else: the EPS-16 Plus main board has an internal header, J9 “OUTPUT EXPAND (INT)”, right under the OEX jack, and the OEX-6 board has a matching 14-pin header, J1 (it’s how the rack version connects). From the schematic, the pins are:
2, 4, 6, 8, 10 ground,
13 −15.6 V, 14 +15 V,
1, 3, 5, 7, 9 data and clock,
11 and 12 not connected.
That lets you test header to header through the cable.
Results with the crossover cable connected:
+15 V, −15.6 V and ground all land on the right pins (under 1 Ω).
All five data and clock lines land on the matching pins. The clock line reads about 850 Ω through a resistor on the OEX board.
No swap between +15 V and −15.6 V.
No short to ground on the supply pins of either unit.
So the crossover cable is the correct one for the OEX-6 on the EPS-16 Plus, and my cable wasn’t the problem. One thing I noticed: the used OEX-6’s jack was slightly misaligned with the case hole, and twice while testing the plug wasn’t fully seated even though it felt like it was in. Maybe that happened the first time, I don’t know.
I’m waiting on fuses for F1/F2 and will power up the EPS on its own first. The OEX-6 isn’t going back on until I know it’s OK.
Has anyone tested an OEX-6 on a bench supply, or had one fail in a way that blew the EPS fuses?
