Hi i’m max from Italy.
I have a question about my Roland d50.
It transmits aftertouch via midi to cubase, the aftertouch slider works but aftertouch doesn’t work with interbal sounds.
I switch on the aftertouch. Parameters in common part and for the parts!!
Can you suggest me some info?
Thanks max
Hi Max, checkout Google.com in the search bar type in your question. How to turn on Roland D-50 Aftertouch on internal keyboard. If you don’t find your answer there, then ask in a different way. Maybe ask, Turn on D-50 aftertouch. Sometimes it will lead you to the Owners Manual. Or you can type: Roland D-50 owners manual. Hope this helps my brother
