Yamaha Clavinova CLP-300 - No Sound
Yikes. New here, and posting for the 1st time. A bit complicated, but impressed by the tags stuff.
Anyway - I was given a non-working CLP-300. It powers on. There is no sound when played, and no “hiss” from the speakers. I did feed a signal into Aux in, and that works. I’m somewhat adept at tube amp repair (Fender, Hammond) but this is a whole new world for me. But I live to learn and fix things. I did find and download the service manual.
Any pointers on where to go from this point would be greatly appreciated.
Hello,
Do a factory reset
Check the voltage on the memory battery, replace if most likely dead. I think its soldered to the motherboard so you may have to take it to a tech to replace.
Then do factory reset again.
if still doesn’t work, then take it to a tech.
Ask at your local music store for an appropriate tech.
Hi - and thank-you!
Ok, well there is no mention of how to do a reset in either the owner’s manual or the service manual. So some searching came up with several ways like power-on with the highest white key help down, power on with lowest white key held down, and some others. None did anything.
So, the battery. Seems like a long-shot but I’ll dig in and check it out.
In the end I don’t have much hope that I can do much with this unit. And I doubt it is worth whatever the repair cost would be if I took it to someone who knows what they are doing.
Onward …
No battery and no Factory Reset in YAMAHA CLP-300 (very old)
Since you done the AUX in/out check we now know that amp and mute relay are OK.
Funny part is - AUX in is sent to the amp AFTER the Master Volume slider. Therefore - the problem could be as simple as a faulty volume slider/potentiometer. To check you will have to open the unit and just touch some wires and/or solder joints around that area to see whether the humm created appears on the speaker(s).
If that turns out to be good then have to go backwards and see where the humm stops - but cannot go back further that the DACs (labelled PSD x 2)
Could also be a case of bad electrolytic capacitors in the DAC recovery amps …
Hi.
Wow! Good stuff !
I will get at this as soon as I can. I am recently widowed (widowered?) so I have lots of time. But don’t seem to get much done.
At quick glance, someone has been in there in the past. Screws missing or rounded heads underneath. Not usually a good sign …
I will get on this advice ASAP.
Bob
