Hi guys, found a beutiful Arius YDP164 model in the trash, with the broken stand, the keyboard works fine, had to buy a new adapter, other than that, in good condition but it’s missing a stand.
Where can I find the dimensions of the stand and if there is perhaps a replacement for it, I would appreciate it. Thanks!
Do you have the broken stand? If so, which parts are damaged? What about the pedal board?
There might be parts available for the stand…sides, brackets, screws feet, back panel etc…
The stand for that model is not available as a whole “kit”. But separate parts may be, depending of the color finish of the piano. This would be a daunting and expensive task to order these parts, but may be possible …
I suggest you buying a heavy duty double brace X stand from Amazon and use that.
