ASR10 booting sometimes
Hi Syntaurians
In a previous topic I was repairing the ASR10 PSU of my ASR suddenly not booting after serving without any problem.
Every single voltage is ok now, strictly in the standards of the service manual that I read carefully.
This is what I did in addition :
-Complete disassembly ( it’s a SCSI version )
-Checked every ribbon cable pin to pin continuity ( all OK)
-Complete disassembly and cleaning of the keyboard / keybed
-Checked the 20 pins connections on board ( even desoldering the connector and resolder and checked ) checked continuity of the ribbon between the two halves of the PCB keybed
-Checked every card, every connector, Remade cold solders after inspection with a microscopic camera ( every old solder point was eliminated with a pump and remade properly )
-Digital Board ; checked everything, even the continuity of the OTTO chip from each side of the PCB, checked the few square chips, repositionned the ram to make sure…checked every single resistor on each card
-Careful reassembly with all the screws, and every ribbon in the right place without error.
And it worked as before, responsive and with crystal clear sound and strong dynamics ) !!! :smiley: , but only for 20 minutes… :frowning:
I was playing a song by sending midi to the ASR, I could change, load, modify instruments ( from a SCSI device ) , and after a while, could’nt modify anything, as the ASR was frozen, while keeping the ability to receive and play midi notes.
I shut down, and after , it restarted later for 2 or 3 minutes before showing the same symptoms and now its over again.
Re checked psu, voltages and fuses, everything is fine, even after heating.
Do anyone knows what would cause this?
Are there some thermistors to be replaced on the digital board?
What should I check or replace ? Small condensers ?
Also have a doubt on the voltage that I should read on the analog board ( VR1 thru VR 7 ), they are silkscreenned but it’s not clear to me ( VR6 is silkscreened -15A)
Thank you.
hi, does the VFD screen go blank but it still responds to midi?
have you ever checked over the keybed and MPU on the keybed?
The asr-10 has three MPUs: mainboard, frontpanel and the keybed - all most be working in synchronicity
Hi We-Robot.
Thanks for your answer.
I’ve been off the grid for a while.
The VFD is like frozen, but not blank, , and does not change or respond to any button solicitation on the front pannel, but the ASR still work with external midi input and play notes from external device.
I have to get to the keybed again to check the MPU. I think something is wrong there.
In addition to solders is there anything else I can check and how?
Thanks
