Casio HT-6000 Fried Power Section
Hey guys,
I’m attempting to repair my Casio HT-6000 synthesizer. I’ve used AI to assist in parts identification/schematic reading, however for fear of AI hallucinations I figured I’d like to get a second opinion, and perhaps some additional insight from folks who have experience working with synth circuits; namely power sections
I’ll include some images to start, and then some considerations from the AI…
HT-6000 PCB, Schematic, Parts List
Basically, AI is telling me the ‘burnt out’ component part-number for a compatible replacement from Digikey is BD442GCT-ND. I couldn’t seem to find that on Digikey. The closest being a BD442G. The 2SB1117K I suppose is not made anymore? Additionally, it was telling me to replace 2 150 Ohm resistors that are visibly burnt. Which I can see those components also got chewed up that are right next to the T4 burnt component. I just mostly want to make sure this information is correct, and ultimately, based on what you’re seeing, if replacing just those three components would be sufficient to get this puppy up and running again - or if there are other things to consider.
The detritus and blackness on the PCB below doesn’t actually seem to be that big of a deal, I just haven’t cleaned the carbon up yet.
I’ve had this synthesizer for years and unfortunately had roommates that liked to ‘jam’ awhile back, and coming home from work one day, it suddenly never turned on again. Whether spilled drinks or an incorrect power supply was used, I can’t say. But seeing as it’s a fairly rare instrument I’d like to get it back up and running if possible.
Thank you for your consideration!
Sorry, I can’t see the images in my region. Not sure why this is a problem admins?
It looks like Imgur might be region specific.
But! I searched for a non region specific image hosting site and found “postimages.” Let me know if this loads for you.
The link to the entire HR-6000 service manual is here as well. the PCB in question is the MA3, I have an image somewhere with that stenciled on the board..
Anybody? Still have the synth exploded out. Trying to get some components ordered for this weekend to try and fix it. :upside_down_face:
Hello,
what makes you think the components around T4 are faulty ?
You should check for a short circuit (between +V and GND) downstream of T4, and inspect the junctions of the active components. Replace anything you find defective.
Then, clean everything, check the continuity of the traces, replace T4, and perform a test with no load. Once the power is restored, you will need to check for short circuits on the other boards before reconnecting everything.
