I have multiple issues on my piano.
First, when you plug it in the piano automatically starts up. You can then shut it off with the power button but it will not power back up with it. To turn it back on you need to replug it into the wall, pressing the power button only makes the power light brighten but does not turn it on.
I could live with that, but now the piano is not playing piano sounds anymore. It makes this awful distortion/static sound, no more piano sounds. You will occasionally hear a key or two under the distortion but never a clear key sound alone.
This happens with headphones and over the speakers both.
I have looked at the capacitors on all boards inside and did not see anything leaking or bulging, fuses are fine as well. Super frustrating.
