Quick question regarding my Ensoniq SQ80… It is a 220V unit and i can use an external converter of course but I would like if possible to just turn it into a 110V US unit.
From my research it looks like simply replacing the Power transformer with a 110V US version is all it takes but im also not expert enough to just assume it is the case.
Yes that’s true. Additionally transformer physical size varies with its power rating in Watts. So find one that physically fits while meeting or exceeding minimum power rating required. Check original 220V unit for its power rating. Oh mounting holes for attaching machine screws are usually not spaced same distances apart. Tis a hassle. You are lucky if they align and match original spacing. Good luck.
In theory this would be nearly true. You also have to change the primary fuses (the 110V transformer draws twice the current).
In reality you will have a very hard time to find a suitable replacement. The transformer is very special. Assumingly only a transformer from a sacrifized 110V SQ80 will do the job.
