My brother passed me a D-50 some time ago. I never powered it up, but he had mentioned key issues and a battery issue to me at the time.
A little stupid, but didnt power up the unit before starting all this.
Opened the unit and replaced 3 keys (got the keys from you guys) and the CR battery. Used your procedure for the new keys. Took extreme care with everything.
Powered it up and nothing, on power up got the
“*** Expanded Linear Synthesizer D-50 ***
Roland Corporation Musitronics” on the screen.
(I assume that is has the expansion card in the unit.)
Then, powered it off, and then on again, and now I have nothing on screen, only the red light next to VALUE. Tried INCREMENT and Zero and nothing.
If I leave the unit off for about about an hour, and power it up again, I get the same thing, the message on screen. Then power down and up, again nothing, just a blank screen.
Now it seems it just goes to the blank screen.
given the message came up I assume the screen is working.
Recognising the battery was changed, that would mean all the data is lost,
would that also mean the diagnostics are gone as well?
Would really appreciate some assistance from anyone that can help.
I am not an electronics person, but I am a tech, so I will do my best.
Extra Info. Just talked to my Brother. He said only way he could use the unit before was with a Card. Noted that he “thinks” he powered the unit up with the card in and was then able to use the unit. He is going to try and find the card.
I have a small midiman unit that I can use the upload the data to the unit if I need to do this… but I am concerned about not having diagnositcs options.
