Ensoniq ASR-10 Replacement LCD
I recently acquired a very nice ASR-10. It’s the late production version with the purple LCD instead of the VFD.
I’m sure that huge VFD display was quite costly and Ensoniq was simply trying to cost-reduce existing products like any company. That’s the same reason you see later versions of the TS-10 Plus with an LCD.
Considering that a custom LCD wouldn’t be nearly as cheap as a common off-the-shelf part I would bet that these LCD’s are, or at least were, available as standard LCD displays.
My ASR-10 has only one problem and it’s with the LCD. At some point (before I owned it) it was exposed to some hefty pressure on the display bezel. This caused the LCD to have a color shift in the background and upon further inspection it caused a single crack across the front glass. The bezel isn’t cracked. Look closely at the attached shot and you can see the crack running through both of the words “system”.
The color shift isn’t nearly as obvious as it appears. The camera was having a hard time getting the color balance right in this photo. Nevertheless, you can see the purple area in the upper middle.
This has not caused a leak in the membrane or any other functional problems. It actually works fine. Still I would like to find out the manufacturer and model info of the LCD. I’d like to replace it with a newer display maybe even a different color.
I have never removed the display in my ASR-10 and that is quite a chore so I figured I would ask if anybody has done a teardown on an ASR-10 with the LCD and discovered this info. Pictures would be awesome but any info would be great.
Thanks,
Scott
The manufacturer of the VFD displays stopped making them - that’s what prompted Ensoniq to shift to using the purple LCDs. It probably was expensive for Ensoniq to manufacture a new display board to accommodate the new display - I’m guessing it cost them rather than saved them money.
IMG_7478
I have a couple characters out in my VFD display in my ASR-10. I can still navigate if I keep my place, things like sample rate are unseen so I have to fumble through and I look through the manual a lot to remember keystrokes when I can’t see.
However humorous some of the sample titles get with the dead characters, I am trying to find a way to fix this!
Do you know if I need to replace the whole display board? - I noticed Syntaur is out of stock -Thanks for your time!
IMG_7469
Another screen on the display - reading “A -10”
Hello,
Same problem here on my ASR10 Rack.
A few green characters are dead.
Does it mean I need to change the whole display board, or is it possible to just change the defective screen?
Or is possible to repair the screen?
Thanks for your help
Regards
Ed
not necessarily.
Apply some light measure to the 4 different corners, separately, of the perspex which is against the VFD. At the ever edge where it meets the metal frame. See if any of the characters return. If so you have a bad solder joint.
Re do the solder joints.
yup because Ensoniq has to come with a method and circuit to convert the old-signals for VFD to LCD.
Someone has reversed this work and come out with a replacement LCD. Whilst VFD will last a very long time indeed, one day it will expire.
Hello,
I found a complet new front panel for my ensoniq ASR 10 RACK.
Is it complicated to take off the old panel, and replace it by the new one ???
I am not a technician man
Can someone please share his experience on this subject ?
Thanks
Ed
Did you ever get any help on this? I recently started messing around with my ASR for the first time in a while, and was thinking about trying to replace the screen which is missing a couple of characters. Thx!
My SQ-80 had this same issue with the display. I opened it up. Sure enough. It was indeed a cold solder joint. Quick touches with the soldering iron and the display is like new.
Hi,
I was looking to replace my ASR-10 screen with a more modern alternative and came across a couple of things:
First is this guy who sells drop in replacements:
https://maruniolcd.com/
very expensive but also very good looking
Before I found that i also saw a guy trying to make essentially this product who dropped his efforts onto Github:
Hopefully from all this you can find a solution!
