Ensoniq EPS-16+ Problem
Hey, I turned on my Ensoniq EPS-16 Plus and the pitchwheel started giving random entries, and it is messing with the Volume and Sequencer controls. I unplugged the wheels cable from the main board and connected back up after some hours, nothing changed. There’s probably a chip that died. Does anyone have any idea of what’s the chip? Or what might be actual problem? Thank you.
I have a similar issue with my ASR 10 rackmount data slider. If I touch it just slightly it jumps to random numbers and letters as well as settings. I pushed it all the way down and am not using it. I have to use the up down left & right arrows to make settings. I have no idea what’s wrong with it. Except it may have dust inside of it or I need to remove it and replace it fully.
