I got an Mr Rack and it’s main and aux outputs seem dead. I can use it via headphone outs which are ok.
I wanted to fix the main outs, assuming that it had a separate jack board like the Mr keyboard, but to my surprise when I opened the case I have seen that the whole of the motherboard, including the outs is just a single piece.
Do you think it is possible to find the motherboard only for a decent price ?
I have a similar issue: no main, aux AND headphones output. You may try theSoniq guy out in San Jose, CA. I think he replaces boards for all kinds of Ensoniq gear and claims to have worked for Ensoniq back in the day. He’s pricey, in my opinion. He also requires that you send him the bummed part you want to replace. But for an entire board, he may be your only option.
Well, I’ve already emailed him a couple of days ago, but haven’t received a response yet.
I see some sort of irregular soldering just around the output jacks, on the resistors. ( fortunately, the headphone out splits before that on the motherboard ) It may be a previous fix attempt or may be the original factory soldering was not proper and has gone bad with heat. I will also show that to an electronics repair person here.
I suspect that the jack auto sense mechanism was somewhat making it tricky to repair in my case.
As I live in a far far away Galaxy, it would cost me more to call them than the ensoniq box itself.
Here are the pictures attached that show the red resistors I was writing about. And also a general overview of the board. It would be nice to compare with yours…
Kindly note that the headphone out is also of studio quality, without any noise or hum. So I believe the normal outs would even be superior.
Thanks for sharing your board view. Here’s a complete board in hi-res for maximum zoom-in.
Looking forward to getting the sound on my MR Rack bad settled.
Curious: is your headphone/volume assembly board crooked in-place? Mine is leaning down toward the chassis.
The manufacturing date on my MR Rack is: 05/01/97
S/N: 13656
I’m betting the culprit is probably an op amp (one of those two-channel 4556 chips nearby). With an oscilloscope, you should be able to see signal at the inputs, and most likely one of them will show nothing at the outputs.
As Sam says. The op-amps, DACs or the capacitors (for decoupling?) around the outputs are usually to blame.
Repairable by someone with some basic knowledge. I may even part with my MR rack, but it is 240v and is fully expanded, so it probably doesn’t meet your requirements?
Edit: Actually, I think they’re 100-240v switching supplies on these?
Well I can consider that, in case the price is reasonable. I can use my existing one as spare parts. My email is [email protected], kindly let me know .
Unfortunately no, upon closer examination I’ve seen other soldering attempts underneath and above the board. I have to record new stuff within months so can’t spare time to fix that. Will use the headphone outs for now.
I am having this same issue with my MR Rack. It was making odd noises from its main outs and signal was cutting in and out. Eventually I got nothing from the outputs on the back, but it is working otherwise and sound great from the headphone jack. Mostly just documenting that this seems to be a really common issue, but if anyone has more advice that would be welcome.
I just bought one and have somewhat a similar problem. from what I have read it seems to be the way it switches between unballanced and balanced - and has to do with a few of the opamps that take care of such things. I will be probing the problem with a scope, the nice thing is my outputs still work for about 4 min but then die which should help be find the problem. also fromrom what I have read, its a common occurance in MR’s (61,76,rack) SD-1 and the ASR-XPro, or basicly the last of the lineup before they got closed down by creative (bastards!) A chap who had the problem with the ASRx-pro (found on asrxite site) seems to know where to look as far as the signal chain. there are very few caps on the main board but there are some - all panasonic but quite little, suface mounted stuff. I have to replace the battery so I can check the caps a bit more closely. But I will keep in contact with this site for progress on my rig.
In my humble opinion and experience of restoring Ensoniq SD1, I would advise checking the “binding” of the output path of MR for compliance with the previous generation of SD1. And if you mentioned that similar problems with the disappearance of sound at the MAIN output were common for SD, MR, ASR - then you should check the circuit diagram of these synthesizers for compliance with previous generations of SD. But it’s unlikely to be useful for users who do not have experience in repairing radio electronics and reading electrical diagrams of these synthesizers.
Based on my own experience of restoring the SD-1 synthesizer, I encountered and studied the signal flow diagram from sound generation, then through the FX processor to the buffer operational amplifiers to the output circuit, where there are also protective elements consisting of field-effect transistors and strapping from Lo-pass filtaring capacitors. According to these functional diagrams, it is necessary to understand and check the integrity chain of the audio signal using a simple audio tester or oscilloscope.
And this is no longer a superficial understanding of electronics when searching for a malfunction in a synthesizer. Therefore, it is easier to contact a repair shop for complex household or professional equipment. here is my experience of studying SD-1
