Ensoniq VFX circuit issue?
A few months ago, I decided to try to replace the fixed battery inside my Ensoniq VFX with a battery holder to make future replacements much easier. Normally, I’m OK with DIY soldering de-soldering, but I was struggling a bit to get the battery out with the braided desoldering tape and might have damaged a printed circuit path right near the battery leads because when I soldered in the new holder and put in a verified battery, my VFX came up all scrambled on its display and doesn’t play any sound.
Are there qualified repair shops out there that could address something like this, perhaps by finding the damaged circuit path and jumpering it, or shall I consider my board gone for good? I am in the NYC/New England area.
Thanks,
Steve
Steve, did you reinitialize the VFX after replacing the battery? You need to do that to reset the ‘Low Battery’ message, and hopefully it will unscramble everything at the same time.
Press the Presets button, and while holding it down, press the first (upper left) soft button on the display. The display will hopefully then read ERASE ALL MEMORY AND REINITIALIZE? Press the button for YES (I think it’s the lower right soft button - press it even if everything is still scrambled).
Hopefully this will bring you back to life. If not, try removing and replacing the two EPROM chips that contain the operating system (the two socketed chips on the main board with paper labels).
Good luck!
I replaced my battery a few months ago with a holder and put a new battery in it. My display isn’t scrambled, but still says it has low voltage. I reinitialized it as recommended, but still have the low voltage warning. I put a CR2016 3V battery in it. I’m thinking it’s either the wrong battery, or I need to get a little more solder on the pins to enable better conduction. I’m not sure which.
I’m not sure if this is the reason for the Low Voltage message, but a CR2016 has pretty low mAh (milliAmp-hours), which is a measure of basically how much juice the battery can put out for how long. The original battery in a VFX is a 2032, which is rated at 190 mAh. A CR2016 is only rated at 80 mAh, so it is going to last only 40% as long as it should. So I think you’ll definitely want to upgrade there.
If I recall, I have had the same trouble, where replacing the battery and then reinitializing did not get rid of the ‘Low Battery’ message. But I don’t recall what the final outcome was - it seems like the message went away after a while, maybe after numerous reinitializations…
