Hey y’all,
I’ve been fixing a busted 16 plus (trying to, at least) and am at the point where everything is working. Sounds load, samples great, keyboard is doing just fine, but after its been on for a couple minutes all the outputs start heavily distorting to the point that the volume slider had no effect on the output from zero to 100.
I’ve been hunting in the d/a section for any wonky caps for grounding issues but haven’t found anything yet. Anybody dealt with this issue in particular? Got any hints as to where i should be looking?
you can skip to the last 20 seconds of the video for when the problem kicks in.
Thanks in advance! https://youtu.be/nlSTW0WLdJw
