Fixing sticky keys on a Korg C3500
Korg C3500
I disassembled my old Korg C3500 digital piano to fix several sticking black keys. I have the keybed disassembled, and all the old grease removed using 91% alcohol and Q-tips. I also cleaned and degreased all the keycaps and weights/hammers.I am using Molykote 44 Light grease.
The problem is when I regrease and reassemble a white key - when pressed, the key goes down and sticks in the depressed position. Ironically, the black key I have tried seems okay. I am certain that I have reassembled the keys correctly.
Tests I have done:
  1. with no grease and no spring, the keycap moves freely without any resistance.
  2. with grease and no spring, the keycap still moves freely.
  3. to attach the spring, I set the keybed on it’s nose so that the keys are vertical (so I can attach the spring). Greased and with the spring now attached, the key works fine - in this vertical position.
  4. laying the keybed flat (in its normal position) the key now sticks.
  5. changing the amount of grease used doesn’t seem to matter.
I am confused by this. My only thought is that somehow the spring is pushing the key forward, causing it to stick somehow. But if that’s the case, then why didn’t it stick before? And why doesn’t it stick when vertical?
Any tips/thoughts would be appreciated!
Thanks, Woody
Wimberley, TX
