Hello,
I own a Yamaha CLP-645 digital piano, and I’m currently experiencing an issue with the right (sustain) pedal. While playing, the sustain occasionally cuts off even though the pedal is fully pressed down. This happens intermittently in the middle of a piece, making it quite frustrating to play expressively.
I’ve already tried the following:
- Unplugging and replugging the pedal unit cable
- Checking for loose connections or dust
- Power cycling the instrument
The issue still persists, which makes me think there may be a hardware problem, either with the pedal mechanism, the sensor, or the internal cable.
Could you please help me identify:
- Which spare part(s) I would need to fix this issue?
- Whether this is something a user with basic DIY skills can replace on their own?
- Where I can order the correct replacement part(s)?
Thank you very much in advance for your help!
Best regards,
