Hohner String Performer - two notes sustain when they should not
The first and second “b” notes do not mute when the key is released. We repaired a dead neighbor note by replacing its 4ch NAND IC, which did not change the “B” release behavior. Otherwise, the unit is performing as expected.
If you have seen misbehaving sustained notes on this unit, or other advice - input would be appreciated.
Thanks,
Mark
