My transpose button is not working properly, I get no continuity in the right 2 pins (like I do with all the other switches on the board). Since these are out of stock here, I’m wondering how I would go about fixing the switch, or at least trying to. Thanks!
Maybe try some contact cleaner. Easy enough to give it a shot, with minimal financial commitment or risk to the unit.
Check the solder points on the switch and make sure there’s no cracks. You may just need to reheat the solder and fix those cracks.
