I 'm looking for a 2003 Casio WK-3000 POWER SUPPLY
It’s an AD12 1.5a with ground core and an L shaped power tip. There are a lot of near matches on Amazon and eBay. But genuine Casio adapters cost $41-$46. That’s a lot of money for a near match that may or may not work. Interestingly I tried a 9 v adapter from Casio, and it came on.
Looks like a standard 12v, 2A centre negative power supply. Loads on eBay for $15
Hi, I recently bought a Korg M1 Keyboard on Reverb.com. Of course it had no power adapter cord. I didn’t want to wait for the seller that forgot to pack it to send it. He lived in Canada, I live in the U.S. I did a lot of homework to ensure I was buying the correct one on Amazon.com I got it and it works perfectly. My advice to you is simple, do as much research as you can to ensure you are buying the correct wattage, voltage, amperage and shape as you mentioned. For example: If the cable you need is a 110 and the one you find closest in all specs is a 120 that’s fine. A little more capacity is better than less. Less capacity will do damage. Hope this helps and best of luck.
P.S. some may look exactly the same as another but they may be different as for as AC/DC type, positive and negative DC/AC etc…. Don’t ever go by looks… go by specs or you could ruin it’s mother board components and power supply, also cause a fire. Get it’s exact specs for your machine and the correct plug, even if it costs more. It’s better to spend a little more, know exactly what you’re getting instead of ruining your entire machine and having to deal with then buying an entirely new machine that will cost you 100 times more money. That makes no sense. Be smart… do the research so you know exactly which kind you need and exactly which kind someone is selling you meets all specifications
paj692, the WK-3000 wants a Casio AD-12/AD-12U: regulated 12VDC, 1.5A minimum, center-negative, 5.5mm OD x 2.1mm ID right-angle barrel. A regulated 12V/2A generic is safe; the 9V Casio adapter is not. It may light the panel, but the amp, backlight, and reset supervisor will brown out and can latch unpredictably. Avoid unregulated “12V” wall warts; their no-load voltage often runs 16V to 18V.
Before plugging any candidate in, meter it. DC volts, red probe on the barrel sleeve and black on the center pin should read about +12V. If it reads -12V, it is center-positive and will reverse the rail. Confirm the right-angle plug seats fully; a straight 5.5/2.1 plug may not reach the jack contact. sargfowler’s 2A rating is fine only with correct polarity and regulation.
BigMikeD63 is correct: specs over looks. What no-load voltage and polarity do you measure on the adapter you are considering?
