Please can I order Motif ES7 contact board to fix inside Motif XS7?
No, the ES7 uses metal leaf contacts, while the XS7 uses rubber contact strips.
The XS7 uses three separate contact boards. If you let us know which one you need, we can get pricing for you (the High board is listed already).
Please I need the middle key contact panel tagged āCā which usually carries the key Contact IC. Below is the link to the screenshots of the key contact board.
Thanks.
Ok, here is a link to that board:
Thank you so much. I will revert as soon as I clear the issue with my previous order. I really need this.
Also could the key contact ic be at fault?
