I have a Juno-106 with new chips and fully calibrated. I noticed distortion when playing chord with some good base,
The distortion sounds like fizzling, (bizzzzz) and only starts crackling when all oscillatorr and sub are on (set to 16), vca and volume maxed and playing the lower bassy notes
the distortion becomes louder when maxing the
Distortion becomes louder (but less than #1 above) when maxing volume and VCA normal at mid.
Distortion significantly get reduced when chorus is off but still there.
I tested the audio path and 99% sure the main audio module board(oscillators board) is outputing clean audio at TP1 and TP2
On tbe jack/chorus board, i can tell at what stage it starts appearing. Im using audio probe to check it and also oscilloscope. The reason why im saying this is that the patterings i hear inside the chorus board are different from what i hear on the main output so im confused.
Keyboardist, your clean TP1/TP2 means the voice board is not the culprit. The fizz is generated after the VCA sum, most likely in the chorus/jack board summing opamp or its supply. Scope the +15V and -15V rails at the chorus board while holding a low chord with all oscillators and sub at 16, VCA and volume maxed. Look for rail sag or more than 50mV AC ripple. A tired 4558 or dried electrolytic there will clip asymmetrically on bass-heavy summed waveforms; chorus off only removes one gain stage, not the fault.
Probe the volume pot wiper and the output summing opamp input/output. If the signal clips at the opamp output but not its input, replace the 4558 and check its feedback resistors. If it appears only at the BBD input, check MN3004 bias and MN3101 clock, but do not shotgun the BBDs.
What DC rail voltage and AC ripple do you measure at the chorus board under that full chord?
I had something similar happen to me, brought my keyboard to The Good Guys is St Paul, MN. They traced it down to voltage issues stemming from the power supply circuit board, they recapped it as well as recapped most of the main board as long as they were in there and that solved the problem. More power draw thru bad capacitors = distortion.
Thanks, i checked the supplies at the chorus board and the voltage have NO AC componenets. Pure DC even with all oscillators (saw, sqr, sub) being on, vca and volume maxed.
i used a proper studio monitor instead if headphones to probe the distortion. When back and forth on the audio paths and this is what i got:
The distortion is first detected at the outputs of the two chorus chips MN3009 (pins 7 and 8).
Adjusting the gains by ear does impact the distortion but CANβT eliminate it. Re calibrated by manual steps one last time just in case and still no luck.
The common sense points to the chorus chips but since the distortion is almost equal on both, im thinking there might be something common to them is causing, unless this is how they commonly fail.
I think the next logical step is to replace mn3009 chips (not the clocks).
A side note: i uad the juno for a few year and even though it had abd voice chip which at the time i replaced (with another original ised chip)i dont recall noticing specific this distortion issue. Clim thinking if there is someting about these new chips ( Borish Electronics) that is provoking the issue. With that being said , i fully calibrated the juno back in the day when first replace the single voice chip and now after all were replaced so pretty sure voltage and audio signal were at their proper range.
