So, I recently installed the Analog Renaissance GS voice chips. When doing the calibration all of the voice chips worked except for the first one. Possibly I might have to check the soldering, but not too sure what’s causing it not to work as of now. All of the diode’s/capacitors etc. look fine, no corrosion or soldering that looks cracked. Not too sure if I should re-seat the voice chip and then go from there?
Never mind about all that, got it taken care of!
Now you’ve tweaked my curiosity. Lol. What turned out to be your problem?
Hey, basically what happen is that some of the traces around where you install the voice chips ( the circles around the IC sockets ) lifted from the circuit board which made the contact not stable therefore the voice chip didn’t work so I had to replace some of the traces for it to run properly. Other than that, all of the things that I had to replace on the synth are up to par. Soldering can be somewhat tough to do, but for the most part I got everything back together
