Hey, can anyone give me any tips on how to add a colored, lighted, Juno 106 bender? I see you can buy the clear bender but how/where do you solder in the led lights?
MikeP
You would be on your own for how to set that up, as there is no pre-existing place on the Juno to mount the LED. You would also have to power it from somewhere, and perhaps wire in a resistor depending on the color of LED you choose (different colors of LEDs pull different amounts of current).
Hi, I need a bender replacement for the flexible plastic part that attaches to a metal bracket and the pot. Where did you get your clear parts?
The clear bender lever and bender plate are both listed here:
Roland Juno-106 Repair Parts and Accessories - Syntaur
All the parts are in alphabetical order, so look under B (for bender).
