I have a Jupiter 6 and Juno 6 that both occasionally retrigger notes. I am sure it is to do with corrosion on the common wire and the key contacts. I’ve tried cleaning the Jupiter’s contacts in the past, and it fixed the issue for a time. The fact that it came back so quickly makes me think that I must not have done it correctly.
Can anyone refer me to the “correct” way to clean up the contacts? Are there certain products I should use/avoid?
When I did this the 1st time, the issue was green/blue liquid collecting at the points of contact, and various other metal interfaces along the common wire.
Thanks!
