Kawai es6 power board
[Kawai [ES6] – [power board out]
Need power board - KEP-281
• Model kawai es6
• Symptoms power jack broken
• Tests already done :+1:
• Photos / none
Ranzie, the KEP-281 jack failure is mechanical first. Pull the board and inspect both sides at the DC barrel jack for cracked annular rings, lifted pads, and hairline trace fractures. If pads are intact, fit a matching through-hole DC jack: confirm 5.5 x 2.1 mm versus 5.5 x 2.5 mm center pin, center-positive polarity, and 2 A or better rating. Reflow with leaded solder, then epoxy the jack body to the board for strain relief. If pads are lifted, scrape solder mask, bridge to the next via with 22 AWG solid wire, and reinforce before reassembly.
Verify the adapter label voltage and polarity before applying power. Check the board fuse, input electrolytics, and regulator output under current limit. A jack that reads correct unloaded can still collapse under load from a cracked pad or dried filter cap.
Post a clear photo of the jack pads and the adapter label. What exact DC voltage and current does the label state?
The jack will not properly seat - looks like in the jack something is broke
Used ohm meter to check connections - read ok
