Korg 01/W Keybed Felt Replacement
Hi Syntaur,
I’m a new forum member and Korg synth owner from the UK.
Having recently purchased my Korg 01/W I need to replace the keybad felt strip due to knocking noise on key release.
I noticed that you have a keybed felt, part #6855 for Korg. Is this the correct part number
for this synth and if so how many are required to cover the 61 keys of this keybed.
many thanks for your help
Dave
I’d be interested in the same too, anyone?
Dave, #6855 is the correct felt stock for the 01/W keybed, but it is bulk strip, not a pre-cut 61-key set. The 61-note bed has two felt runs: the rear upstop rail, which causes the release knock when compressed, and the front rail downstop. Measure the old runs before removal; the 61-key frame is roughly 33 to 35 inches per rail. Order two strips for a full felt job; one strip only if the front rail is still resilient and you are just curing the release knock. System100m, same answer.
Use 1/16-inch wool felt, not adhesive craft felt. Scrape old glue with a plastic scraper and naphtha; do not soak the frame. Keep the aftertouch pressure strip and key-contact rubber undisturbed, and do not pinch the ribbon under the keybed. Re-seat all key return springs evenly and check that each key tail just kisses the new felt without preload.
Before ordering, press one key slowly and watch the key tail: does the knock originate at the rear upstop rail or the front rail?
