Hello everyone ive joined this community to see if i could get some more insight on my korg 01/w pro, i got an answer on reddit, so the problem is that it no longer powers on, after i had forgotten to power it off one night, i was told it was something to do with PSU caps, and that is a definite indication lf acidic of outgassing from caps, i need more help on how to look at this and if there is a specific part to replace, thank you
I have the same problem, did you fix it?
Did you check the voltages from the power supply?
Take out the Power Supply board and re-solder the components on the board. Check all continuity. Re-install and see if it powers up. Also make sure the power switch is opening and closing first.
I opened it up im jot sure if i see anything wrong so ill send a picture, i was told it could also be a fuse but i dont have a multimeter to check
You need to check:
1: Power supply voltages +5v , +/- 12v
2: Current draw of the mainboard on 5v rail. It should not be more than 400ma
You will need digital multimeter and a power supply which displays the current draw.
Do this checks and we will see what comes next.
Regards
I checked the fuses with a multimeter,
fuse 1 gave me around 0.6
Fuse 2 gave me moslty 0 although it did spike up to 1.6 for a sec
fuse 3 gave me around 0.2 and 0.3
Fuse 4 gave me 0
Also sorry i did not understand what you meant by a power supply, do i need to test the power supply too?
And i also did not understand the 2nd question
You need to check the voltages on the power supply.
Tirdad is asking for you to then measure the current consumption of 12v and 5v.
Set you meter to Amps measuring and put your probes inline with the 12v and then 5v power rail.
The only thing you need to check with a fuse is continuity in the rare case that it has blown. Did you check the voltages as suggested? Your meter would be set to DC V. Assuming your transformer is still working, I’d be pulling the board and examining the bottom for leakage and/or broken solder joints. I’ve had more than one PSU board that looked good from the top and then I found very bad acid damage below. Be sure to label every wire with its number from the board. Wear a ground strap. Unplug the power.
The 01 is an old synth, and it’s coming due for a recap. I had to recap both my Wavestation and M1 which roughly preceded this. The M1 was leaking badly and needed a bunch more than just caps.
