Does anyone have a Korg DW-8000 repair or service manual? I’m pretty sure that some component that provides the amp output has died a silent death recently, as I get no output from the L/R or Headphone on my otherwise well-kept beauty.
I’m going to get medieval on the insides of it soon, and see if I can see any signs of source of the problem. At this point, I don’t even know the various boards or other internals to reference them even if I do find something, so any kind of schematics, SM’s, etc, would be most appreciated!
I have repaired the L/Mono input jack now. Solder joints were wonky and the JALCO housing was loose and not seated properly underneath the second point. Ground appeared to be good, as did the positive, but I gave them the touch up for good measure. Continuity appears to be good where it logically makes sense for it. Don’t see any capacitors blown, and nothing appears to be out of sorts to my semi-trained eye.
If anyone has any documentation on the flow of signal, the full path of signal from the voices to the jacks, I would be most grateful, so I can make some sense of what I should be testing if this doesn’t fix the problem.
Cheers!
-d
I uploaded now also some other stuff: owners manual, instructions for replacing the battery, cassette dumps of the factory (?) sounds as *.wav-files, which you need after replacing the battery.
And I made a simple page for it: http://www.florian-anwander.de/korg_dw8000/
Florian, Thank you so very much for your consideration! I appreciate it VERY MUCH! If I were there, I should like to buy you a very large, very cold, very fresh, very delicious beer, and then I would toast you with it! Then we make music!
Cheers!!!
-DT
Born and living in Munich, Bavaria, (for some known as the world head quarter of breweries ) I really appreciate the offer of a cold fresh beer. About the size you don’t have to to worry here (@Sam will know what I am talking about. He spent a week here in Munich while the Oktoberfest some years ago - and we didn’t make it to meet, because he was always urged to sit in the large beer tents)
Hello Javaweiss,
I have not. Shortly after that last exchange, life happened in a big way, and until I saw your reply, I have not thought about it. However, I will have some time coming up where I might be able to really look at it, which is going to be great. Plus, now I have some tools of the trade: oscilloscope, decent DC power supply, decent volt-meter, a few hours under my belt.
When I do, I’ll post back here. It’s funny, you never know where life is going to take you when you least expect it.
Cheers!
-dt
Wow thank you so much for replying! I went ahead and ordered a new output muting relay on eBay cause it was only a couple dollars and thought I’d see if it solves the issue. I think it’s a long shot cause I don’t see how this would cause parameter slider not to work. I really hope you find the time to crack yours open again so I can follow your lead!
