Korg M1 stuck on “Init Prog” — need repair advice
Hello! I’m trying to repair an original Korg M1 (61-key).
Symptoms:
  • On startup, the display shows KORG Music Workstation M1 #25, then Init Prog.
  • The INT and PROG indicators remain lit.
  • The keyboard produces a piano sound, but the factory programs (such as Universe) are missing.
  • The internal battery has been replaced.
  • Changes to program parameters can be saved and retained after power-off.
  • I tried reloading the official factory preload file m1preld.syx using MIDI-OX and Bome SendSX, but the display and programs did not change.
  • I also tried requesting program dumps over SysEx, but currently receive no MIDI input data when attempting a dump from the M1.
I have checked the global MIDI channel, EXCL is enabled, and Memory Protect is OFF.
My question: What hardware or memory-related faults could cause this behavior? Is there a reliable way to determine whether the problem is with the main board, program memory, or MIDI interface before replacing components?
I would appreciate advice from anyone experienced in repairing the original Korg M1. Thank you!
