Korg M3 No Sound
Working on this M3. Keyboard seems to check out, I’m not getting any sound from the module at all. Pads and keys show up on-screen, faders are running when playing pads or karma or drum tracks. Tried it disconnected from the keyboard. Checked the output jack board, nothing seems to be amiss. Tried hard reset and reload all preload data. Any other suggestions?
Try this
http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=65926
When connecting the M3 to another synth or computer via midi, does it generate any notes on the slave device ?
If it does then most likely the issue is internal. It could be due to many reason, i hope its as simple as broken fader(seen it once).
If havent already, disconnect EVERYthing( canles , usbs, midi, pedal…) and inly keep headphones and power it on. See if you getbany results.
Fyi, i’ve just experienced dropping audio issue due to a connected pedal.
