Korg microKorg E.2.1 Error - No Sound, Output Thumps on Arp/Patch Change, Service Tests Fail
Korg microKorg E.2.1 Error - No Sound, Output Thumps, Service Tests Fail
Work Done So Far
Power supply recap:
  • Most electrolytic capacitors replaced with equivalents, A lot were out of spec.
  • Power rails now measure stable (no voltage drops noted at any ic’s)
Service mode testing:
  • Mode 1+3 (Auto) gives E.2.1 error (also displays Rom ver 1.03)
Audio behavior:
  • When audio is input to [audio in jack #2] the led #6 will flicker and VR will change input level.
  • No sound output from any patch, no sound from keyboard, no sound from input #2.
  • Demo mode will start and switches patches 1-8 and a pop can be heard between patches. No popping from audio input.
  • Previous owner mentioned: vocoder failed first, then total silence
What still needs confirmation:
Need Help Understanding where to look next? Is IC14 supposed to be ground-side control to produce the sounds since pins 2-5 have 2.5volts? I have a rigol DHO802 scope, I see a lot of activity from the DSP, I am however no expert at confirming if its sending the right data. DSP IC17 has power, ground, clock, shows communication with IC14 ((AK4522VF). DAC IC14 has power, ground and square wave on pins 10-13. Pins 2-5 have 2.5 volts. I really need help trying to pin down both the DAC and DSP, I’m thinking those are the most likely suspects, but then again it may be something else. If anyone out there knows how to help me diagnose further, it would be greatly appreciated.
Did a bunch of searching and everything points to damaged chips from an out of spec power supply.
BUT you have already replaced the caps and verified the supply is stable, now its just finding the damaged chips.
Some I guarantee are no longer made and you need a working parts machine for those.
At this point my only advice is to determine which chips are intermittent, damaged or non-functional, then find a parts machine to 1st verify the failure in the working machine, then swap those bad chips for good chips.
