hello
Has anyone serviced a korg sp-280? I need the disassembly pages from the service manual or info on how the cabinet comes apart…
Anyone??
There doesn’t seem to be a service manual available for this.
There’s a video on Youtube https://www.youtube.com/watch?v=a_x5fOiIBxg&t=22s which says it applies to the SP range of keyboards.
Otherwise, takes screws out from the base making sure they are ones that hold the top/bottom together
I suspect there is not much difference between KORG SP-250 and SP-280.
Just turn upside down on a soft surface and remove all the screws around the perimeter, then turn back right side and list off the top. If still no go … there may be a row of screws further in from the perimeter at the rear edge to be removed as well.
All-in-all not that difficult.
Thanks, job successfully done
