Kurzweil Midiboard (short logic board) v3 Upgrade
Kurzweil Midiboard – V3 Upgrade
Hello and greetings from Germany!
I have a Kurzweil Midiboard with short logic board. It was upgraded to v3 with a daughterboard. When I boot get error “7 ERR” which means that there is a problem with the non volatile RAM.
I opened the hood and saw that the red and black wire from the daughter board got loose. As far as I understand those two wires a soldered to the legs of the 6116 at position U14. I can see some solder residue but I dont know which cable goes to which leg???
Can anybody please help?
Maybe somebody knows where it goes or owns a short logic board version and can open the unit and send a photo?
Thank you so very much for any help!!!
Best regards
Clemens
Here is the Data sheet for CDM6116AE2 looks like one of the wires were soldered to pin 4/ address 4. Most of the time the length of the shorter wire when cut could only go to one of the 2 pins of U14. Locate the soldered on the other pin then see which of the wires make it to that pin easily. This is only a guess. Have you looked for the schematics?
You can purchase the installation guide at this site online. If available it should show where the wires go. Good luck!
Kurzweil Midiboard Keyboard Version 3.0 Installation Manual
Contents: (Installation Manual).
Note: This procedure describes the necessary steps to install the version 3.0 Software upgrade. (Dated 1987) (12pages/$10)
