I have a Kurzweil SP88 that seems to have a sustain problem. Using a piano patch and holding the keys manually or using the factory sustain pedal, the duration of the voice is about two seconds before it quickly fades away. I think this is much too short and not what it was originally. Organ patches and strings don’t seem to be compromised, but any of the regular piano patches don’t fade out gradually like an acoustic piano would. I had a Kurzweil authorized tech examine it and he said he had never heard of this dilemma before and brushed it off as normal. Don’t think so…so …
has anyone experience a similar problem??
This sounds like a ROM issue. I have not experienced this per se but have heard that a rom update may help this.
Is there a rom update for this keyboard? I’ll have to check on Kurzweil website.
And if there is, is that something I can do myself or will I need a tech to do it?
Usually it’s best performed by a tech. I did have a spark of knowledge while I was supposed to be doing something else, Try this.
Turn the power switch off.
Press and hold the two buttons marked Panic on the front panel.
Turn the power switch on while continuing to hold the buttons.
Wait until all of the LEDs flash the second time then release the buttons.
After the second flash, the controller software version will be displayed briefly then
the main Diagnostic Menu will become active with PLC showing on the display.
The diagnostics are controlled using just two buttons: Col Select and Row
Select. In general, Row Select will advance to the next entry in the current menu and
Col Select will select the group or execute an individual diagnostic.
I suggest checking the CPU and SND diagnostics as per the manual (https://kurzweil.com/wp-content/uploads/2019/10/SPMAN.zip) and if brave enough try initializing the EEPROM, what this will do is reset all the sounds back to factory.
Again, the manual will explain what each test does and what initialization will do. I will warn you that it will bring the entire thing back to factory settings provided that none of the roms show FAL after performing the tests
