Hi,
Anybody ever had a DX or DXa that the panel lights flash on for a second on startup and then nothing, and no sounds?
Thanks!
Hi,
Thanks!
I would suggest two things:
Hi, thanks for the suggestion Werner. I have good 12v and 5v supplies and reseated all the ICs. I have some odd signals coming off a lot of the chips. I’ll try send a pic later today.
Just to clarify - both +/- 12V are OK and +5V OK as well ?
Thanks again Werner,
They checked good on my DMM but then I looked through my oscilloscope and there was a decent ripple on on the 5V! Im going to replace some caps and I’ll let you know how it fairs.
Thanks!
Hi!
I struggle with a very similar issue right now. When I turn it on, only a parts of LCD flashes (and some buttons leds, but not every time) for less than a second and then nothing… Only power switch lights on.
Did you find any solution, which finally helped you?
Thanks a lot and regards!
Jan
