Hi there, I have an Oberheim OB-8 that I am trying to get it going and I am posting this to see if anyone has encounted these problems before - which do not seem to be documented online.
This is an early OB-8, with a Panasonic keybed and a factory added MIDI board. It has the B-5 ROM chips in it. Apparently something fell onto this Oberheim, and the top board was extracted and moved to one with an undamaged front panel. I have been closely examining this board for cracks or broken solder joints or cables, and have found none.
When it arrived it had some of the standard problems that are covered in many repair videos already. The LED’s all came on and responded but there was no sound. After some time the synth started to respond and worked over MIDI with my Arturia keystep, although some funky things would happen when knobs got turned.
The power supply had seen some previous work, with the filter capacitors replaced. However, the original rectifiers were still in place. I replaced them with new bridge rectifiers, including one rated for a higher amperage on the 5V line. There was some damage on the board from the original 5V rectifier, which was overheating the board. It doesn’t look pretty, but as far as I am able to tell, there are no shorts. The voltages are testing perfectly across the synth.
After this repair however, the synth stopped making noise and the LED’s on the front panel were no longer illuminated. Only the bender panel lit up, and in some different patterns when the power is cycled. None of the buttons respond anymore. It will not go into test mode, and does not respond to the reset prodecure.
I have been cleaning sockets, cleaning molex connectors, checking every connection and everything has tested okay. I have tried replacing the factory RAM chips with Synthchaser’s battery eliminator RAM chips (and removing the original battery as per that upgrade). I have replaced many CMOS chips at this point on the CPU board. I have acquired a TTL/CMOS tester for the remaining chips, and all have tested okay.
With the MIDI board unplugged, I am able to get 10V out of the DAC. When this board is plugged in however, it drops to 0V.
Yesterday, I tried removing the MIDI board altogether and relocated the Microprocessor and TTL chip to their original sockets. After this change - the synth started to respond more normally. Front panel LED’s lit up. Buttons responded to pushes. There is some flashing on the LED’s. There is some sound, including the noise generator and some sounds from the oscillators. It is going through autotune and passing it pretty quickly. This is all happening intermittently.
Anyone ever encounter these kinds of issues with an OB-8? Most videos and blogs I have seen haven’t had any serious issues like this and have only had to undergo routine matience.
