Piano won’t power on
I have a YAMAHA - E363 keyboard.
I already know I blew something. I believe I used the wrong wattage power source and I had the good ol (pop) noise - and then the keyboard just faded away on me. I tried batteries to see if it would bypass but like I figured, it didn’t. So what exactly pops? And where is it located? Is it a fuse? Can I buy a new one to pop in there and wa la?? It will work? I have the piano opened up, I’m looking around the power source plug in site and I don’t understand which is a fuse? Sorry and thanks for any help! I can’t find anything for answers anywhere else.
Is it the tall cylinder on the right??
the operators manual doesn’t mention fuses, only that its a 12V ac adapter, and if you plug in something else will damage the motherboard.
Sorry but you need to take it to a tech in your area.
Check the DC jack for continuity. The will break away from the traces at times but look good and they are not. I have repaired the traces and eyelets on DC jack boards before and that might be all yours needs. Good Luck!
Few things here:
  1. Wattage of a power supply has no impact on operation of the equipment unless the wattage a power supply can deliver is substantially lower than the equipment requires in which case it will simply not work as the power supply voltage is “collapsing”.
  2. The PSR-E363 only takes DC on the input but even if an AC adapter is connected it still may work because the unit has a polarity protection diode (D103) in series with the input which does operate like a rectifier and in due course can deliver the required DC voltage for the unit to work.
  3. If the DC adapter connected has the wrong polarity the unit simply will not work due to the afore mentioned polarity protection diode (D103).
  4. If however a DC adapter is connected with a way too high DC voltage the power on/off control circuitry may break causing a short circuit and blow the on-board fuse (FZ101). In any event - if the on-board fuse (FZ101) does blow then there is a major problem in the unit’s power supply and will need extensive repair or maybe the power/amp board to be replaced.
Hi, Great info:-) i have the same keyboard, during the cyclone the keyboard made a buzzing noise and now the keyboard works normal for about a minute, then the screen freezes and nothing works, unplugging it is the only option to restart it. I used a different power adapter 12v , so its not that. Trying to start it again it will not go on, but dispay will just light up whilst my finger is on the on switch. A few hours latter and it will start up again and behave the same.??? Any ideas where to test on the motherboard with a multimeter?
Hello everybody, I have an yamaha PSR e 363 that doesn’t power on.
I’m checkin the power board (PNL YJ069) and i notice problem with the diode D104 e D105 that are burning.
Do you send me the service manual or electrical diagram?and do you send me the specific for the two diode D104 and D105.
Thanks a lot
You can find the service manual for the Yamaha PSR-E363 on this website :
Diodes D104 and D105 are 1SS133.
