Help! I ordered the Cyclone Analogic Beat Bot TT-78 drum machine from a UK based retailer. It arrived with the wrong type of power supply - it arrive with the round pronged European style power supply/adapter. I’m in the USA so I need the USA friendly adapter.
I found this on the Syntaur site but it’s for the TT303. Doesn’t mention if it’ll work for the TT-78.
What is the voltage and amp rating of the adapter? It is likely the same as that used for the TT-303. To use the adapter supplied, you’ll need something that plugs into a US wall outlet, and then has a female plug for the UK pins. I’m not familiar with that sort of thing, and honestly, it’s probably easier to find a US power adapter - hen you won’t have extra pieces that are needed.
