dιѕplay and all ѕwιтcнeѕ are worĸιng ғιne but sound is not coming out of speakers also output and Headphones
ĸιndly нelp
Thanks
God Bless You.
ĸιndly нelp
Thanks
God Bless You.
Ar you using he correct power adapter and is it working OK?!
If that is OK, then … I think you will not have much simple luck with that one - you have either an on-board PSU fail or the main Audio Interface chip (yellow block in picture below) is faulty.
all inputs (red lines go to that Audio Interface chip via ADC chips (Analogue to Digital Conversion) and all outputs (blue lines) come from the Audio Interface chip via a DAC chip (Digital to Analogue Conversion) to the headphones and L/R output or from the Audio Interface chip vai TWO digital amplifiers (one Low Frequency and one High Frequency) to the speakers.
Also - all parts are within the main board (the orange box that follows bottom and right)
You can make one little test and connect a guitar lead (jack lead) to the Guitar and/or AUX input an see if you get that through the speakers
If not - the main fix may be the main board to be replaced - not cheap !!
That’s so kind of You
May God Bless You
can you do this and get any output ?
also - maybe a long shot - do a Factory Reset
NOTE:
This will delete all your stored settings
Demo and Reset is not working I tried Everything
This problem Started in the month of Nov 2019
Before Covit 19
Hope this will not last for 970 days
Thank you so much
May God Bless You and Your Family.
It seems like you’re dealing with a challenging technical issue with your audio equipment. Based on your description, it could be a problem with either the on-board power supply unit or the main Audio Interface chip. The inputs and outputs are all connected to this chip, so if it’s faulty, it could affect various functions of the device.
Have you tried this … that will make it the decision!
I haven’t but I’ll try.
