Repair SL49 MK2 Slider
Dear readers,
I am looking for a replacement slider (which do i need to get?) for the Novation keyboard as it sends rapid value changes even when nothing is touched. I have now suppressed the slider by turning it off via device settings, but internally it is still seeing the changes as my CC values which i have added for serveral different synths via grouped presets are hidden after half a second by the value jumps.
So i mostly only shows CC#16 (hidden) to CC#23 (values of the faders) instead of the latest touched or moved encoder (In my case my CC presets for my external synths). I have already set the touch control to off in the settings, which sadly did not help. I mean maybe there are other ways then replacing the slider, but for now I have settled on this solution, as I think this may be the only one. If you have any other ideas, they are warmly welcome.
PS: In the past I might have updated the software of it or flashed the OS again, so I think this should not help in my case. Any help is appreciated as I really like the keyboard and all the possibilities.
Thank you so much in advance,
Lucas
