Replacement Screws for Oberheim Matrix 1000
Hello,
Can anyone confirm the size of the Phillips screws used in the Oberheim Matrix 1000? There are nine small screws used to fix the main chassis case - three each on both sides and the back. There are also five larger Phillips screws used on the faceplate. Looking to replace both. Any help is appreciated.
Thanks!
If you have any of the screws, go to a hardware store and have them match it to a nut or they will have another method (if they are machine screws) and they will tell you the size. Lowes, Home Depot, local hardware store should all be able to tell you . I was a machinist for fifty years. There are other ways but that would be easiest if they are “machine screws” and not self tapping.
