Roland Contact Board Replacement Required
Roland HP 147 e silent keys
I have acquired a Roland for my daughter however a group of 10 keys in the lower section are not working. I’ve done my googling and opened up to have a look and certainly looks like there has been some corrosion damage at some point and someone prior to me has tried to repair it with no luck.
Therefore I’m now looking for a new board to swap it out. I see in the shop here its something they have had before but is currently out of stock so i thought id ask here incase anyone knew of anywhere i might find one.
The description in the shop is as below:
Key contact board, 39-note (Low), for Roland keyboard. This replacement keybed PCB is Roland part number 7698904000
And the part number matches … so if anyone has one then please drop me a line.
Ever hopeful in sunny Scotland.
Tom
• Model & revision/OS:
• Photos / audio clips:
Hi If you still need one I have a New Old Stock 7698904000, spares@electronicmusicservices.co.uk
Hi there. Sorry i missed this message, yes i do still need one if you still have one?
tomvwallace@gmail.com
