Do you sell a replacement for the Fantom 8 push button encoder, the six which are under the touchscreen?
If not would anyone know what mfgr/model it is?
Thanks in advance.
Thanks in advance.
Hi
Are you referring to the push buttons under the screen, or the large encoder wheel?
Does the screen work ok?, or do the buttons under the screen not make any changes?
Hi, yes, I’m referring to the 6 push button encoders under the screen. I’m looking for a replacement for that encoder part only. Everything works fine including the encoder, except it’s bent and wobbly when turned so would like to replace.
I am also looking for this encoder/switch. I bought a used Fantom and one of them is broken. I have been looking at parts from Bourns and Alps trying to figure out if one of them will work. It looks like I will have to take it apart to see which part they use…
