Roland JD-800 Bender Pot Wiring
Two of the wires (the red and orange) that connect the bender to the main board broke at the potentiometer connection. I should be able to re-solder them, but I was hoping someone verify what order they go in.
The schematic seems to consider the bender assembly a single part and I did not see any details there.
The broken connections are along the bottom of the pot, where the yellow wire is connected, so my guess would be that they go Yellow, Orange, Red, but was hoping someone could confirm.
Thanks!
have a look here
https://reverb.com/item/52959321-roland-bender-jd-800-d70-u20
Thanks! That doesn’t quite show me the connection that I needed. I ended up going with my intuition and putting them in the ‘color order’: Yellow, Orange, Red, and everything seems to be working.
