My Roland R70 shows “serial error” on the screen. It is locked there and will not do anything else. Battery changed out, factory reset done (several times). I have read that it could be a midi problem? Would replacing the midi connectors work. Syntaur has that replacement part. Thanks all.
It is very unlikely that this problem comes from a midi connector, it would rather be an electronic component fault.
